Hi all
I have a 2007 335i N54 with a problem, a leaking front turboseal.
its strange because I have changed the turbos twice and the front turbo starts leaking front the seal right away.
what could cause this?
I have done a leakdown test ,a compression test , smoke test, checked oil return hoses,looked inside engine at oil return ,turbo shaft play, oil thickness ,
oil level in the oilpan, have installed RB ext PCV with blocked headports,
there is no smoking
I would suspect a drain problem, but as stated have already looked into that, I was thinking maybe blowby pressue was preventing the oil from draining but leakdown was good. Also its only the front turbo, and I the drain is sitting a little lower than the rear, but Im aware of the oil level in the pan.
And wouldnt too much blowby pressure affect the rear also?
anyway I could really need some suggestions as to what I could look into
there is no smoking
