paullandre
Hi Guys
I have a 2001 BMW 525i , its got 209 000 km on the clock and i have owned for about two years now. The only faults I've needed to replace was the disa valve and the cam sensor, otherwise no major problems.
But in the last two months things have really started to go south. The car has started to misfire on 2 cylinders , it also struggles to start (takes almost half a minute to get it firing) and has very little power. The cabin fills with petrol fumes, its running very rich and therefore also heavy fuel consumption.The car has also started to overheat when standing in traffic.
On top of that almost everything electronic inside the car has stopped working:
-Multi function steering wheel controls
-Electric seats
-PDC sensors
-Radio
-Instrument cluster (Only rev counter still working)
-Interior lights flickering on and off while driving
-ABS and Wheel speed sensor lights are on
After having fault codes read it indicated faulty MAF sensor,coils, injectors , O2/lambda sensors, fuel pump, wheels speed sensors and I suspect that the cat is also past its time.
I would like to know you guy's opinions? What will it more or less cost me to get these problems fixed (Looking at other threads I'm guessing no less than R30k ?). And is it even worth getting it fixed ?
Should I just cut my losses and try to get rid of it? What can I even expect to get for it? Please guys I'm really desperate for some advice.
Sorry for the long post.
Paul
-Electric seats
-PDC sensors
-Radio
Paul
