Additives
stiaan
Hi guys
Just a quick question, what injector additive can I put in now and then when filling up my 320d, its my first time in the dark side, so I'm quite clueless lol
Sent from my BlackBerry 9320 using Tapatalk
Executer
Inactive
stiaan said:
Hi guys
Hi Stiaan, send a PM to Mo@crazyridez, they stock the Rislone range of additives which is really top class stuff.
Get the Diesel Additive from him, not only will it protect and clean your injectors, it also boosts cetane :rollsmile:
http://www.bmwfanatics.co.za/showthread.php?tid=48207
:thumbs:
andrewbuch
Also Moranor@axis stocks the LiquiMoly additives So depending which make of additive you want you got choices on the forum
Mohammed01234
Try the following Liqui-Moly Additives suitable for Diesel vehicles:
Speed Tech Diesel
Injector Cleaner
Anti Knock Additive
Super Diesel Additive
Diesel Purge
Don't forget to add the most important additive...DIESEL ITSELF :biglol:
I sell Liqui-Moly products because they are proven to work unlike the others. Pricey but worth it
I prefer the NF fuel additives to LM but i can get you both :)
NF injector cleaner is good to put in every 10 tanks or so
R 55 a bottle
If you interested in a smoother engine as well as a clean fuel system I recommend NF Diesel saver you put in in every tank it treats 300l
R90 a bottle
