Actuator questions
Thunder
Quick one for you E36 guys.
Can the actuators in the doors be removed and cleaned to work or must it be replaced?
Reason for the question is my drivers side back door tends to lock and then it either takes months before it unlocks again or I need to remove the whole door trimming and actuator while door is closed.
Also only the boot, petrol cap and passanger door works all the time, rear doors works once in a blue moon for one or two times and driver door doesnt work at all. But if inlock the driver door with the key it only locks the two front doors, the boot and the petrol cap.
Any ideas on fixing it?
