Philip Foglar said:SMG Canal Walk still seem to be using Castrol, so guess what's in my car?! Forsdicks Tygervalley was using Engen Syntium 3000. Not sure what Auric Auto was using since they were the previous service agent that looked after my car before I bought it. What is the root cause of sludge build-up? Is it the lengthy service intervals (2 years or 25k km whichever comes first), or the type of oil?
George Smooth said:Philip Foglar said:SMG Canal Walk still seem to be using Castrol, so guess what's in my car?! Forsdicks Tygervalley was using Engen Syntium 3000. Not sure what Auric Auto was using since they were the previous service agent that looked after my car before I bought it. What is the root cause of sludge build-up? Is it the lengthy service intervals (2 years or 25k km whichever comes first), or the type of oil?
The carbon build up is on the valves due to the direct injection. The sludging or broken cams I have never heard of.
Gizmo said:According to one of the head technicians at auto glen, the e90 engines have such tight clearances plus the fact that the engine oils used are so thin that the cams easily score the cam bearings thus damaging the cams and cylinder heads. I have seen some of the scored cams and heads, doesn't look pretty!!
One more reason to not go for the e90...:nonono:
Coisman said:Gizmo said:According to one of the head technicians at auto glen, the e90 engines have such tight clearances plus the fact that the engine oils used are so thin that the cams easily score the cam bearings thus damaging the cams and cylinder heads. I have seen some of the scored cams and heads, doesn't look pretty!!
imp:
So it would seem that its a design flaw then?? Wonder if you would have a viable claim if your car is out of motorplan and it breaks with this issue?? :dunno:
