Hi, can someone perhaps tell me how i can get to my hooter comfortably. My wires came loose and i tried to get my hand through the indicator opening to re-fit them but was unable to.
Unplug the battery and wait 5 minutes, remove the two screws at the back of the steering wheel and remove the airbag. The airbag and hooter is on the same unit so you should be able to fix whatever you did.
Thanks for the reply, well i guess i should have mentioned that the wires is loose on the horn itself and i didnt do anything lol. The wire terminations is worn out.
So my next question is how do i get to my horn then?
