guccifunboy
today my vibration damper had a total failure, for the second time
over the weekend i replaced my power steering pump because it was not healthy anymore and made a terrible squealing noise. replaced it and all was good. not a sound (besides the usual diesel noise (its a 320D e90 BTW)
then after filling up with fuel the i felt the steering was a bit tight, so i thought maybe the belt came off the power steering pump so stopped and saw it was true, lucky i was around the corner from my dads how and stopped there.
as soon as I turned off the engine i heard a strange noise,opened the bonnet and the rubber section of the vibration damper was off.
now this will be the second time i needed to replace this thing, first time BMW did it, i did my sisters on hers and its running smoothly, but my question is how often do these break because reading around it seems to be a common problem and it pretty expensive to buy a new one every time
or could there be an underlying problem, i know my car has a squeak in the morning when its cold, but that goes away when i replace the belts (BMW only as the others squeak all the time)
i replaced my idle pulley as it was a bit moeg but that was 100K ago.
any help would be appreciated.
