2011 E90 320d EGR
Garreth
Hi guys
Is there a step by step way to do a egr delete? I tried the search function but not sure if it's tapatalk or just me but can't find much to help me....
DieselFan
You can cut the vacuum pipe going to the egr and block both sides of the pipe with screws.
Look for andy1gp thread on his e46 330d. It's in there.
Nikhil
Howzit bud, if im not mistaken your car has an electronic egr valve like the lci 330d so no vacuum lines. If this is the case your best bet would be to get the valve de activated in the software. If it is not electronicly actuated then the above option will suffice
Garreth
Thanks will take a look
Okay how do I know it's electric ?
Nikhil
well there wont be a vacuum pipe going to it, instead it will have a cable and connector. :coolShake:
DieselFan
You're right it should be electric. Unplugging it would probably throw a code. But you could try just unplugging it.
