BMW M
killua said:Olorin: "at higher speed my measly..." What have you been drinking dude :drink:. Given 2 indentical bodies, each with gearing optimized for top speed, the one with the higher power will have the better top speed. The one with the better top speed will have the better acceleration at higher speed. Torque curve has NO influince on high speed if number of gears go closer to infinity. The contrary is that the less gears you have, and power output is equal, then the car with an engine with higher AVERAGE power will be faster. In that case, a diesel engine, even when running at its power peak will still be equal or better than a NA engine of equal specific power output. I have made a nice graph for you to help explain. BLUE IS 320d, RED is 320i.
We will start at the basic torque curves:
Here you will se the fame of the "high" torque peak at low RPM for the diesel. And the mistake you make is by looking at the 320i torque curve between 5000 and 6500rpm and noting it is higher than the torque of the diesel at 5000 - 6500rpm, because the engine does not rev that high. You constantly forget gearing.
Then next graph the torque of the engine is sent through the gearboxes, each with their specific ratios (I have taken 6th gear as a comparison):
Now note that the diesel torque curve dropped, but got stretched. But because the torque is SOOOO much, the torque does not drop below that of the 320i even if needing to be stretched out through the gearing. So there is no high speed the 320i will ever be faster at.
Just to put everything in perspective, I will include the graph of the acceleration in m/s^2 for all the gear ratios. Note that there is no place where the 320i has more torque, hence acceleration, at ANY SPEED, than the 320d:
While I am at it:
1.6i citigolf vs 320i
EDIT: BLUE CITI, RED 320i
Well done Killua! :clap: There is no way in hell that a 320i will beat a 320d in ANY circumstances...be it from robot to robot or top end. Ive taken on 325i's with the Dynamic from robot to robot and 250nm does not beat 380nm... no matter how you cut it.. Top end is a different story thou.
I started this thread to display my dissapointment in the 320i's performance, not to open a can of worms and insult 320i drivers. I agree that the 320i's are nicely speced with extras... but thats it. If you like power, and to take on the occasional Citi golf at the robot... :nono:its not the car to do it in...your ego will not recover... :mmm:
I've driven and owned ALOT of BMW's in the last 14 years (aee my signature), and I have always been impressed with their performance, even the e30 and e36 316i's... but the e90 320i... :nono:
