Hey all
Bought a E46 325ci (2002) end of January, had problems with starter since day one, it swings and swings but always used to start. Started using the car for work regularly and last week on the way home, car just started switching off and back on immediately (Most of the time when I am slowing down/braking, usually in 2nd and 3rd gear. My rpm drops like in split second and before it even goes below 2000rpm. At this point my car is heated much more than before this problem occured). I was advised not to use the car till it is sorted out).
Now that the main problem is out the way, I have some small issues that are bugging me, one being it has the motorsport dashboard in place of the factory 325ci dashboard, and my check engine light is on yellow all the time, could someone please advise me if it could be giving me incorrect warning signs because of the dashboard change?
Another problem for me is the gears are extremely sticky and makes quite a bit of noise at times, and having a regular lack of power when pumping the gas if I need to get somewhere fast.
If anyone can advise me on where I can take my car to have everything looked at and dealt with, without having to put me into debt for years to come.
NB: Also if anyone knows or has advice on where I can take my car to get the interior redone, it would be appreciated. (Please note, dont have a huge budget for this)
Cheers all
Cheers all
