netercol
ouch.. from the mk60 ecu memory (which is the traction control/abs/stability ecu) it would seem like a control unit fault..
no coms (can) , low voltage, ecu faulty.. but since this ecu is part of the abs solinoid unit on the driverside of your car under the bonnet, i think its at least a posibility that the plug is not making contact on some pins (maybe water?)
maybe give it a wiggle or a clean and replug? worth a try..
