ed_z said:12.7s @188kmh 400m with 244 on the KM. I am satisfied but not absolutely convinced or ecstatic to as what my wagon should be doing.
Agreed,with the power you are pushing and the fueling you should be pushing alot more esp on the 1km,how was traction?also last i checked your car was set up for track and not strip mr.Ed_z,still though very impressive time and speed there :thumbs::thumbs:
im sure with strip setup that time will be alot less
DoC1471 said:with the power you are pushing and the fueling you should be pushing alot more esp on the 1km
also last i checked your car was set up for track and not strip.
ed_z said:Thanks guys was nice to eventually run the car for the 1st time on a drag strip.
Did not realize there was one, any car can do it but with the correct ingredients. I tend to play around a lot with my car cos of chasing track day times etc so got a better idea of what works than many others do. There is still 20hp in the car which is on the very limit of everything but at the end of the day I just love driving my Wagon. Funny thing is these are stock settings on JB4, anyone can run these settings they are on the N54 tech site I just select various Maps and go. Tuners would hopefully get more out of the setup with fine tuning, lap top and special codes etc.
Stelios with his GTR R35 runs a constant 11.3 quarter mile with 260km/h on KM and 4 runs in a row without cooling the car down or anything. Those GTR's are very impressive if you look at the engineering side being so efficient, cooling, launch, traction and gearing etc yet brutal! All of the rest of the guys are spraying cars coolers off with water and ice.
____________________________________
Thanks guys! Will be back this week on the dyno to up the HP to see what the max is as this will be the last of the stock turbo runs.
DoC1471 said:Agreed,with the power you are pushing and the fueling you should be pushing alot more esp on the 1km.
DoC1471 said:also last i checked your car was set up for track and not strip
Sherwin@xcede said:DoC1471 said:Agreed,with the power you are pushing and the fueling you should be pushing alot more esp on the 1km.
Not at all. The km is a heartbreaker, you need exponentially more power to run better speeds. Ed's speed are exactly right for his setup. He has a big boost setup making big mid-range torque & all it's power early with a power peak at 4500rpm. With big mid-range boost comes more timing pull up top & more boost taper up top due to pronounced build up of heat during full load in that gear.
Do you know what differences that entails? I do as I have done circuit & drag racing for many years.
Looks like his rear camber is pretty decent. So then you need LSD and sticky rubber for straight line traction. Check, Ed has that. He mentioned he felt his traction was pretty good. There is no strip setup that will make a difference. Except maybe runflats & open diff, I reckon that will make a difference.
ed_z said:There is a slightly decreased footprint of rubber on tar because of the setup nature of the car but nothing as aggressive as per normal track day setup, the rears actually look like they falling into the wheel arches!
911 boxer said:Your photo does not reflect accurately as Ed,s car is running well over negative 2 deg camber on the rears(last time I checked)and that is no good for drags,
911 boxer said:he was also running semis which have very hard side walls which are also not really suited for drags and they need a lot of heat before they work(I am running both bridgestone and dunlops
911 boxer said:I think with better tyres and a experienced DRAG driver Eds 1M will run low 12's all day long.
911 boxer said:I think the jb's are all you need in terms of hardware for tuning a 54-55 motor,they are simply brilliant and Ed has done a very good job of setting(and learning)his car up with it.Well done Boet! :bravo:
