1M Down Pipes
S
SP33DYV
So with me searching the world wide web about 1M oil consumption and run in times and and and, I came across this very interesting fact. The primary cats in the down pipes are different from any other N54 and they are able to deliver much better flow than the other N54 down pipes.
Realoem confirms different part numbers as well.
1M
01 Rmfd primary catalytic converter ZYL. 1-3 1 18307980403
02 Rmfd primary catalytic converter ZYL. 4-6 1 18307980404
135 N54 Engine
01 Rmfd primary catalytic converter ZYL. 1-3 1 18307553594 $957.00
02 Rmfd primary catalytic converter ZYL. 4-6 1 18307553595 $957.00
http://www.1addicts.com/forums/showthread.php?t=691143
http://www.1addicts.com/forums/showthread.php?t=702209
So it is the mid section cats that needs to be removed on the 1M and not the primary cats in the down pipe. This must be the reason so many people use the N55 mid section. The N55 mid section has no cats. So in essence, if you fit the N55 mid section to a 1M, you should unleash some additional horses and if you add S/W like that from ACS, even more. :thinking: And you will still have M/P. :thinking:
S
SP33DYV
444YYY said:
SP33DYV said:
UpNcOmiNg! said:
Doooooo eeeeeeettt!
Don't play games.
You have an N55. :thinking:
You walked into that one Devon!!
Now lend him those pipes... :fencelook:
I don't borrow. He must give them to me. :fencelook:
Jeremy said:
SP33DYV said:
UpNcOmiNg! said:
Doooooo eeeeeeettt!
Don't play games.
i think he was telling you to do it.
I need the N55 mid section from his 135i.
UpNcOmiNg!
Events Organiser
Yes, that true Morne I do have an N55. I'm pretty sure you have facelift tail lights.
Oh well.. :rollsmile:
On the real though, I am allergic to cats :sorry:
S
SP33DYV
:idea: The tail lights cost the same as the N55 mid section. :fencelook:
Use it, or don't use it. :)
will MP be happy even though you patching different bmw parts onto your car that have not been tested together by BMW?
if they are the 1m down pipes would be a MP safe upgrade for other n54...
S
SP33DYV
Sean, BMW will not even notice if you fit 1M down pipes to a 135i, but take a guess what 1M down pipes cost. :dropjaw:
It's not worth the money.
P
petrivanzyl
You'd just be Frankensteining the Frankenstein car some more:fencelook:
lol probably cheaper to buy a 1M?
