Gizmo said:
Wes said:
Gizmo said:
The car sometimes battles to start, you can hear as it's turning over that it isn't making compression. Compression test results don't lie, either way the motor would need to be stripped down to determine the exact cause of the multiple low cylinders. Collapsed rings would be my guess, maybe blown head gasket between cyl 1 and cyl 2.
Maybe toast is the wrong word but it will need rebuilding regardless.
What did the car come to you for originally?
Is the transplant a solution to a problem the car had or is it something the owner wanted to do from the start?
The car came in for full suspension refresh as it's beyond driveable over 130km/h (shaking) and new clutch/flywheel as it's on it's way out and shifting gears is becoming a problem. Unfortunately, the gearbox has a massive oil leak and has been running with almost no oil in it so it is most definitely toast now so I suggested the 6spd idea seeing as we replacing clutch/flywheel anyway.
The 2.8 transplant is something Tumi liked from the get go, the compression numbers of the 2.5 was all the incentive we needed to convert to 2.8i
The current owner test drove the car and he did say the trailing arm bushes needed to be replaced. I also mentioned to him that the control arm bushes needed to be replaced after the roadworthy on the car was done. Its an old car and yes these things need to be replaced from time to time. it was also mentioned that the clutch needed to be replaced as i told him i doubt it was ever changed since new.
As for the gearbox issue you speaking off. I drove this car everyday with no issues changing gears. i sit in traffic everyday and if there was an issue i would know about it after over a year of driving it. The car parks in the same garage spot everyday and i showed him there was no oil spots on the floor.
In closing, the issues that i knew about was made known. If i knew there was a toast engine or toast gearbox i would have kept the car and worked on it myself. I have been on the forum for a very long time and i would not do the next forum member down either.
The current owner can contact me should he feel that i was not honest in the sale in anyway.
PS im in IT and not a mechanic so i can purely go on how the car treated me.
