135 coolant low indicaror.. how do i clear
rsgordini
How do you clear the error for low coolant level?
It showed low coolant and i topped it up..
It went away.. but the exclamation mark is still there. And i fyou check engine test the orange thing with the collant showing low pops up again..
Ybechan28
Check if there is a leak somewhere or check your coolant pump and thermostat. I'm no expert but start with those 2 things , could also be a faulty sensor.
gavsadler
As above- check for leaks. Also did you top up when it was hot or when it was cold? This can also affect the level
rsgordini
First time i saw it i let it cool down (enough for it not to overflow from the bottle.. it needed about 500ml of water.. the float went to top..
Light still didn't go off.
Parked car last night didn't drive it today.. now i checked bottle again, cold completely now...
Needed 50ml very little.. so i topped it up.
But the light still doesn't go off.. try resetting with the left stalk but it just flashes once twice three times and then thats it.. when you turn it off still shows the coolant warning light..
Oh also no leaks at all.. checked everywhere..
tman
The symptoms you describe was very similar to what happened to a friend of mine over the weekend. Turns out his waterpump was on its last.
Sent on the move via Tapatalk
rsgordini
Just so you guys know . Tried many many things.. eventually tried removing the bottle to get to sensor..
So it wouldnt clip out and i didnt want to break it so i moved it around a bit and put it all back.. wanting to research it more...
Then i get into rhe car and low coolant is gone.. do a check and all ok..
Yay..
Just needed a good shake up it seems..
colinza
I had the same error on my 135, took it in because it was on motorplan and they replaced the water bottle and sensor. Seems to be a common issue - pretty cheap though.
Also - first post, hello all :)
