Hey Guys!
I'm new to the forum. Used to have a 2001 Audi A3 1.8T and have now moved onto greater things such as my 2006 130i M.
Anyway, The car is great has around 104000KM on clock and is amazing!
I wasn't sure about this car at first at fact that it's NA and so on. Adding to that what I've read on the forum in some posts comparing the 130 to the "Hatchbacks" with SW DP etc etc... HOWEVER!!!
When I saw THIS!
It blew my MIND! This is a local vid as you will notice in the dialogue, and judging by the scenery could be at the coast, however not sure.
Now for some of the nitty gritty... This is my first BM. SO the general control of the car's heads-up display and the works is a lot different to my Audi's... Forgive me for sounding like a tit, but here it goes.
For starters, WHY is there no Temp gauge? and how do I check the oil level??:flyfun:
Then, my car seems to have a mind of its own by idling a little higher all on its own and coming back down to its normal 800-900. It idles up to about 1000... Also when I push in the clutch, the same thing happens.
Is this normal? if not, what could be the issue?? Air flow sensor??
I checked the service book, and according to the book, last service was done at 87000kms, its on 104***km now, when I went through the service checks the next oil change is in 10000ks. I know with my Audi I had to change the oil every 15000k's... So i'm just a tad confused as to how many k's she can run with a fresh oil change...
That pretty much wraps it up. Is there anything in particular I should watch out for? Electronics etc... Also I wanna put a sub in the boot. (i'm in my early twenties - Don't judge me!):tease:
Ideally I want to extend the motor plan, any ideas on how much this will cost??
Sweet!
When I saw THIS!
Sweet!
