George Smooth said:Today was the Sport Compact 3 event at Tarlton. After fitting the methanol injection I knew I would beat my 12.5 time set at ODI. When I went to the track my intention was to try get a 12.4. The weather conditions where not so great with a head wind again and scorching heat but this worked in my favor traction wise.
First run I always do a bit of a feeler so I ran a 13.0 with a 186 exit. Car felt excellent. Second run was a 12.5 with quite a shitty launch. Next run I managed to pull it perfectly under the conditions and ran the new record setting 12.37@185. I did some minor adjustment with the methanol on that run just to get it to flow a bit sooner to combat the heat and it worked out perfectly.
I then parked the car for the day. People thought I was mad cause they where offering me there race seats etc to lighten the car and run a better time but that has never been my intention with the car.
I would like to thank Chip Logic for all the work they have done on my car. I would also like to thank my hair stylist, gynocologist, bar man and whoever else I have forgotten. :excited:
Avi 333 said:Could you tell me what methanol injection system are you using?
Matt Q said:Are you running a LSD and if so what make?
George Smooth said:Avi 333 said:Could you tell me what methanol injection system are you using?
Hi Avi,
I use a system from Labonte Motorsport. I chose that one because the way the wiring is its easier to remove from the car as I am not planning to run the meth full time. They also the only company that has a controller that you can map the methanol flow in 3D. I do not have this controller but wanted to know the product I got could be very advanced with add on's.
Avi 333 said:George Smooth said:Avi 333 said:Could you tell me what methanol injection system are you using?
Hi Avi,
Thanks.Im still doing research for my car .havnt made my mind up on which system to go for.
http://www.labontemotorsports.com/store/ccp0-catshow/Gasoline+Systems.html
Which one did you use:dunno:
George Smooth said:I use a system from Labonte Motorsport. I chose that one because the way the wiring is its easier to remove from the car as I am not planning to run the meth full time. They also the only company that has a controller that you can map the methanol flow in 3D. I do not have this controller but wanted to know the product I got could be very advanced with add on's.
20VT said:Well done on the time - its a fantastic achievement :clap:
FRC HFS-2 system also allows mapping of the methanol flow in 3D automatically by tracking the Injector Duty Cycle thus maintaining the correct water(meth) to fuel ratio always
