My F30 330d M-Sport
Clint@MMS AUTO
The above detailed breakdown is what Clinton provided daily with photographic evidence per step. The service received was phenomenal. Daily communication, meticulous attention to detail and solid advice from someone who doesn't just want the Client to waste money but get value for money
I am super impressed with the top tier workmanship from MMS Auto and will continue to support them
Hey Mr, thanks for the kind words šŸ™. I must have sent you like over 100 pics this week lol sorry for all the spamming :ROFLMAO: but I'm glad you're sorted now and the car is safe to be enjoyed again. šŸ¤
unobeat
I am so happy that MMSAUTO is back in business and posting again on Facebook as i follow their work on Facebook religiously.
I have them used them in the past to sort out brake pads on my wife's car and i continuesly engage with them on Facebook.
@Anees - Your car is extremely neat and clean. I am loving how OCD you are with maintenance. Keep it up
Anees
:ROFLMAO: my gallery is full
Thanks for all the tlc on the car bro, much appreciated. Super excited to pick it up tomorrow 😁
Anees
I know the feeling. I was super excited when I heard as well
Thanks bud. Trying to keep the car in good condition. Car is at that point now where things need replacing due to age and mileage
I believe that if I take care of the car, it will take care of me
There are some items which are beyond my DIY capabilities which I leave to the professionals. There are some other items which Clinton will be taking care of during the year
Anees
Update - 218 7xx km - ISC Coilovers, Minor Service, Engine & Gearbox Mounts
On my last visit to @Clint@MMS AUTO, we noticed 3 items on the car that required urgent attention:
  1. Front disks and pads
  2. Shocks
  3. Engine & gearbox mounts
Front disks and pads were sorted out immediately on that visit with the shocks and mounts being left for a next visit
I was initially set on going with Bilstein B4 shocks but then started thinking about what if I wanted to go lower in the future. I had 2 options to consider initially:
  1. Bilstein shocks with Goldwagen shock mounts + Eibach/H&R at a later stage
  2. Bilstein shocks with OEM shock mounts + Eibach/H&R at a later stage
After speaking to a few people and reading up, it was recommended to go the OEM mounts route. This became quite expensive and I would be wearing down the shocks quicker once fitting the lowering springs
This is when I started exploring the coilover route and made contact with Mo from Ultra Racing. After having a 22 minutes initial conversation with Mo, I knew everything that I needed to and opted for the ISC Advanced Kit. Height and 32 level damper adjustable with camber plate/front pillow ball bearing mounts in the street comfort spec
Kit was ordered at the beginning of June and arrived a month later
I have not driven the car much as yet, but in the test drives that we did while dialing the car in and the drive to Clinton thereafter, the car drove very well and feels almost like stock. There is still adjustments that can be made to both dampening and height but I am happy with the current setup. I need to go back after a 1000km for final adjustments
Straight after fitting the coilovers, the car went to Clinton for the following:
  1. Replace Engine Mounts - OEM
  2. Replace Gearbox Mounts - OEM
  3. Perform Minor Oil Service - Motul X-clean, Mann Filter
  4. Perform Undercarriage Inspection
Clinton finished with the car yesterday and performed super work as always. I'll be picking up the car from him tonight and will report back on the ride quality after putting more miles on it
Safe to say the car is now once again in good health!
Anees
After commenting on @Twincam Shark's thread of "F30 - 330d Highest Mileage", I might as well drop the car's service history here as well
Current Mileage - 229 100 km
DateMileage (km)Service TypeDetails / Parts Used / Notes
07-Apr-23141 000Vehicle PurchasedSee specs, mods, and previous service history above
02-Jul-23150 000Oil ServiceMotul oil, Mann oil filter
14-Aug-23154 924Coolant FlangeCoolant flange leak - OEM Replacement fitted
07-Oct-23160 000Major ServiceMotul oil, Mann oil filter, Liqui Moly Ceratec, Blueprint air & cabin filters
15-Feb-24170 000Oil ServiceMotul oil, Mann oil filter
15-Feb-24170 000Cosmetic UpgradeBlack and white BMW badges installed
11-May-24180 000Oil ServiceMotul oil, Mann oil filter
03-Aug-24190 000Oil ServiceMotul oil, Mann oil filter
09-Nov-24200 000Major ServiceMotul oil, Mann oil filter, Liqui Moly Ceratec, Blueprint air & cabin filters
14-Nov-24200 806Tyres ReplacementGoodyear Eagle F1 Asymmetric 3
17-Feb-25210 100Battery ReplacementFirst Battery LN5AGM, 36-month warranty
01-Mar-25211 000Oil ServiceMotul oil, Mann oil filter
21-May-25216 098Front Brake & Diff OilFebi Bilstein front discs, Hella Pagid front pads, brake wear sensor, diff oil Motul Motyl Gear 75w90, coolant flush 50/50 mix, brake fluid tested, coolant pressure tested
02-Aug-25218 700ShocksISC Advanced Street Spec Coilovers. Height and Dampening Adjustable
04-Aug-25218 778Oil Service & MountsMotul oil, Mann oil filter, LM Engine Flush, OEM Engine and Gearbox Mounts
Anees
Update - 231 987 km - Major Service
Managed to overshoot the 10,000 km service interval this time thanks to work and other travel commitments, but the car has now had its major service.
Parts Replaced
  • Motul X-clean oil
  • Mann oil filter
  • Mann cabin filter
  • Meyle diesel filter
  • Febi Bilstein air filter
The car hasn't been seeing much use lately since we've picked up a cheap daily. The 30d is now mostly reserved for the wife's occasional grocery runs, along with our Centurion–JHB and Centurion–FS trips.
Schalk94
Parts Replaced
  • Motul X-clean oil
  • Mann oil filter
  • Mann cabin filter
I saw your car on John Vorster Ave a while ago.It looks so clean and well kept. Kudos to you for keeping it in top shape!
Damn Anees, not sure how I missed these updated however not sorry since it gives me some good reading time.
Love the updates, the coilies are tops! Car looks perfect!
Anees
Update - 233 9xx km - Ferric Grey 437m's
Been wanting a set of these for a long time, but finding a set in Ferric Grey proved quite difficult. When the opportunity arose, I had to grab them.
Fitted them on 19 August and I’m absolutely loving the look. They need some minor TLC, but nothing a refurb won’t sort out down the line.
The set came with Vitours:
235/35/19 - Front
275/30/19 - Rear
I've read that the rears might rub with the 275's but all seems fine with me so far over the approximate 200km's of mixed driving that I've done. Perhaps I'll change to 265's if I get any rubbing with passengers
The pictures really don’t do them justice.
