discussion Comparison of 2015 vs high mileage 2015 vs low mileage 2017 F06 640Ds: purchase warnings
aibtus
A friend of mine saw my f06 2017 640d msport model with 86,000km and has gone shopping for something similar.
So far he can only get a 2015 f06 640d grand coupe msport model with 156,000km and a 2013 grand coupe individual model with 133,000km.
Help me advise him on key differences in these cars in terms of infotainment, any software updates, fuel usage, recalls, differences in engines (if any) and other long term maintenance risks. He is planning to keep the car for 4 to 7 years .
Are there any glaring items to watch out for and significant changes from 2013 to 2018????
aibtus
Dude, I lost you at 2012.
Hard to keep track of the years from the title to the post....
Then i really got lost with 2015 high mileage vs low mileage.
Maybe edit post....
Apologies, was typing too fast on w small device. That heading doesn't make sense even for me now 😒.
Let me edit it.
aibtus
Heading should read
Compare a high-mileage msport 2015 BMW 640D to a mid-mileage individual package 2013 BMW 640D gran coupe
PsyCLown
This will give him some insight into the changes based on the year: https://en.wikipedia.org/wiki/BMW_6_Series_(F12)#Yearly_changes
Seems as if it is the N57D30T1 engine throughout the F12/F13 life. He has your car as an example to know what it should look like and how it should drive and perform etc.
I have heard that the 40d engines, even on the newer B57, seem to have some issues with the small turbo (the one which provides boost lower in the rev range). How much of a problem this is, I am not sure but something to keep in mind.
Swirl flap & EGR delete I believe is a good idea on the higher mileage engines, especially if you plan on keeping it for quite some time and adding a fair bit of mileage to it.
Get the gearbox serviced at ZF if the mileage is low enough and you plan on putting lots of mileage on it.
Some of the 640d's for sale do not look great IMO. So best he does his due diligence and thoroughly looks into the history of the vehicle before purchasing.
Pisancho
I'm with Psyclown on his points. If your friend has at least 50k to repair stuff then it could be fine but he should be prepared to spend to get it up to scratch.
ColinvS
Thank you for the feedback 😁. I have advised him as such
Maybe to add that the LCI was 2015 onwards - quite subtle changes with the front lights (and bonnet and bumpers etc). Oddly 2 of the 3 640d's I test drove (with under 125k mileage) had turbo issues - no low down boost so assume the small turbo was the problem.
Did your friend end up buying one?
Pisancho
Yeah, the 535D also has issues with the smaller turbo. But they make almost 290kW with a stage 2 tune, very potent motors. Turbo recon is relatively cheap (under 10k) so still worthwhile in my opnion to get a 640D or 535D.
ColinvS
Definitely make sense - that is a proper rocket with Stage 2!
Did you have the ZF gearbox serviced at ZF? Well worth it - did the 420d and the F25 X3 2.0d. https://www.bmwfanatics.co.za/threa...00-vat-incl-1-30-june-2021.96192/post-1532060
ColinvS
Did you have the ZF gearbox serviced at ZF? They recommend it at between 80k and 120k km - I usually get it done at 100k km to be safe - but as they say oil is cheap but engines (and gearboxes) are expensive. https://www.bmwfanatics.co.za/threa...00-vat-incl-1-30-june-2021.96192/post-1532060
