F SERIES X1/2-ACTIVE TOURER/Countryman serious flaw
So my mother in laws 2 series Active Tourer 20D went into lip mode.
2 weeks ago it thew a gearbox error, which i thought is the Aisin geabox that needs a gearbox oil change.
Once at the workshop they determined that it was a faulty fuel sensor that begins to leak, causing diesel to flow down the fuel line, to the wire harness, then into the DDE (ecu). If too much fuel gets into the Ecu, it could be catastrophic.
Upon doing research i see this is a massively mentioned and discussed issue on all Bmw platforms that transversely mounted engine, or front wheel drive layout.
They were lucky enough that they were able to dry out the ecu and no serious damage had occurred.
So this is a headsup to any owners, its worth spending the money every 4 years or so and replace the fuel sensor that is prone to leaking.
This was mentioned recently on the forum...apparently the sensor can be swapped out as preventative maintenance - but how effective is that ...we won't know.
If im not mistaken, this issue is specific to the b47 transversely mounted engines
Quite unfortunate - considering these are mostly well priced diesel options in the current market.
If i did own any of the Cars prone to this i would definitely change the sensor (R1800 for a Bosch) every say 3 years as preventative maintenance.
hansi06
Yeah mine happened at 6 years/65 k km.Fortunately under motor plan.
Thanks for the reminder, it's been about 3 years since.
Is there a quick way to check if it is leaking? How hard is it to swap out?
Its seems if you take the engine cover off, you will be able to see if there is a leak:
seems like it could be something you could do yourself
A lot of guys abroad also replace the fuel line while they are at i:
DRCraig
Agree completely. Disappointing to say the least for potential X1 20d buyers. Another reason why this forum is imperative for obvious reasons.
I think for someone who has this info, they are still great buys. You know to treat as a preventive maintenance and check it often and replace the sensor ever few years
