The OEM discs were causing the shudder?I also had my X3's discs and pads replaced last week due to a very slight shudder when braking. It was R26k all around. This was on 57k km on the clock. Apparently a common issue on the G01's.
Apparently yes.The OEM discs were causing the shudder?
Did you go with the TRW pads from Imcomex?So I bit the bullet and went ahead with it:
Front discs from BMW: R5880
Front pads from Imcomex : R700
The guys at BMW East London gave me a nice 15% discount, so worked out to R2900 per disc
Yes, apparently TRW is the supplier of BMW OEMDid you go with the TRW pads from Imcomex?
Cool. Yes, seems so.Yes, apparently TRW is the supplier of BMW OEM
Yep, I have Meyle discs allround on my 520D and F15 rear all paired with TRW pads. Haven't had any issues. Generally, Meyle is a good quality brand. They make lots of parts including suspension and filters.Thanks for this - just received a quote from them.
Meyle discs @ R3778 for the set
TRW Pads @ R700 for the set
How does Meyle compare to OEM?
I see. Imcomex quoted around R1900 for Meyle discs plus delivery to EC would be +-R400.Yep, I have Meyle discs allround on my 520D and F15 rear all paired with TRW pads. Haven't had any issues. Generally, Meyle is a good quality brand. They make lots of parts including suspension and filters.
In an ideal world that made sense the 2 piece rotor would have much cheaper replacement costs as you would only be replacing the friction surface and not the hat.I see. Imcomex quoted around R1900 for Meyle discs plus delivery to EC would be +-R400.
So at R2900 per disc from BMW it wasn't too bad.
Still do not understand why they decided to use two-piece lightweight rotors for a 520d. I checked my 330i F30 and that doesn't even have two-piece rotors, nor does my 320d E90. I can only thing it might be due to the weight of the car.
How is it going so far.Update on this. Installed the new brakes myself today. Took it for an easy drive, brakes feel good, especially for new brakes that haven't been bedded in yet.
Brakes are great now. Will always go OEM from now on when doing brakes. Zero vibrations and stopping power is 100x better.How is it going so far.
