That post should have had a bit more detail...I have undeservingly not driven or spent as much time on this car as I'd have liked. I "fixed" the sunglasses holder with 2 magnets, it now normally stays closed unless you are going sideways on a skidpan where shades will go flying into thankfully closed windows...
I have half-heartedly been chasing the stumble off idle issue. Replaced the rear TPS with a new one (the store only had stock of one) and gave the ICV and throttles a quick clean while I was in there. It did not solve the stumble issue, but I will replace the second TPS before giving up. I have noticed a few other S54s doing the same thing, so maybe I need my mental TPS reset.
Grubby:
Clean (-ish, could not get those stains off the brass). Bonus side effect: I need to buy a new crank vent hose as mine broke in twain 😠
Figured I'd update the ECU, this definetely made the car feel more responsive, but that may be due to the adaptations being reset and the ECU learning all taking place on the skidpan. Break them in hard, I say! It still stumbles tho 🤷♂️
Was slightly scary, took about 3 beers to update, started worrying if I had maybe bricked the car. Deffos have the car plugged into a beefy charger as the fuel pump remains running through the whole process!
Grubby:
