Will update once done, might only be done in two weeks. your car unfortunately does not have this.Keen to see the result of this, in what way is the car smoking, constantly on idle, or when coming to a stop? mine is again smoking, but not as bad as before, but on deceleration almost at a stop, when i give it gas again, i see the smoke still. not always, but sometimes.
never constantly on idle, only some times, some times coming to a stop. before the oil it was smoking too but Fuel not oil, so make sure of this.Keen to see the result of this, in what way is the car smoking, constantly on idle, or when coming to a stop? mine is again smoking, but not as bad as before, but on deceleration almost at a stop, when i give it gas again, i see the smoke still. not always, but sometimes.
Thanks man, yea I checked online a few times and I don't see these listed, nor can I find anything internationally on a forum, as well as them ever being brought up in topic.View attachment 28488
Browsed Real OEM on M6 ( and if i guessed right ) but not on your vin and found this, so it might be it on yours but it does not list a part # for it.
Yea yours is routed completely differently. i know there are some innate differences on the XxM variant S63 cars.The two pics above is how mine is running completely different from yours.
All the best man.So fetched the kit today. Will be able to start with this only in a wek or two, From the look of thing wont be a quick task but one that will take some patience and time to get to the actual valve covers to remove and replace the oil seperators. The check valves is built into these. Hence most of the time replacing only the PCV lines does not remedy the oil burning issue.
