Replacement Discs and Pads
Deeso1
Hi Guys, hope url well. I need to replace my front brake pads and discs. Obviously I want reliable brands, but also dont want to spend a fortune, need good priced reliable brand. Saw some of the guys saying sure brake is good and somebody also told me about LMB brand. Please can any of you recommend good quality affordable brand for discs and pads and pricing. I have a 2016 F30 320i Msport.
evnmopwr
I used SureBrake on my e46. no issues other than it seems to run down Allot faster than ATE brand. and makes hell of allot of Brake dust.
Just my Experiance with them
For over 25 years i have been buying brake parts from Midas/Autozone local spares shops, Ate, Feredo, alfa they all perform about the same and cost virtually nothing. If its a run of the mill car that you not tracking dont waste money on anything else.
Clint@MMS AUTO
Goldwagen sell Hella Pagid, Febi Bilstein and surebrake.
All 3 will get the job done but I usually go for the Febi or Hella pagid stuff.
Swiegie1
Hi
My only issue with aftermarket Discs is that the hub section rust on most aftermarket brands. My OCD cannot handle that, so I stick to OEM discs and pads.
T
Hi
T
Use rustech spray on the exposed parts and copper grease on the hub and it will be a non issue atbthe fraction of the price. Im also ocd about these things but im also a scrooge 🤣
I cringe a little when people tell me they paid 10k plus to change disc and pads on a normal car.
Sibonelo
I had a experience with aftermarket disc on my e39 530i. I bought aftermarket set and after 3000km they warped and car was shaking, skimmed.. same story. bought another aftermarket set, same story. ended up buying OEM after recommendations of a BMW specialist. 20k km later I'm all good.. but on my e36 I never had that issues.. so it can be hit and miss
I did Hella Pagid on the Porsche. It has a coating that doesn't seem like it will rust. YMMV as I guess it might be different for different cars. This was brand new BTW. The hub portion looks the same still after washing a few times and some rainy weather. It was not the cheapest, but still the same price as one disc alone from Porsche so can't complain. The difference vs. surebrake was not big enough for me to think about going with a 'house brand'
M3boi
The Surebrake discs are also coated and don't rust. Will replace E90 discs with Surebrake when the time comes, had very good luck with them on the E36 considering how hard it gets driven.
Swiegie1
Hi
Thank You. I am just looking for a disc that will not rust. Do you also use Surebrake Pads?
I want to get a quote on these VS OEM.
Thanks
KR_19
I've got a situation and question to add to this thread.
My F30 340i was due for front pads towards the end of last year. These were replaced with Febi pads and the existing brake discs were skimmed.
The rear pads were then done earlier this year and I went OEM this time as I can't handle the occasional squeak from the fronts (even though it rarely happens). The rear discs skimmed as well.
Over the past 2 months I've been noticing at higher speeds (100km/h+), that there is a slight shudder when braking. Last week I drove to Grabouw with a somewhat heavy foot. Let's just say I went more than 100km/h... and the vibration is a bit more noticeable under braking.
I had a suspension and shock test done this past weekend to make sure everything is fine. Everything is perfect and tyres are good. The two shops that I've gotten advice from both say that it can only be the brake discs. With 86000kms now on the clock, I feel it may be good timing as well for new discs.
My question is should I stick to OEM and is it worth the premium for brake discs? I am leaning towards this option, or are there upgraded discs anyone can recommend for similar cost to OEM?
Or do you guys recommend saving a few bucks and strongly recommend a "cheaper" aftermarket brand?
Sent from my SM-F956B using Tapatalk
You can buy oem and still save a few bucks by not buying from the dealer.
Had the same issue on the wife's car before as well as my 320d... it was the discs so whenever I changed after that especially on the M135i, I just got the OEM parts and it never had issues again.
Because to resolve those issues, I replaced with OEM and never experienced it again on those same cars.
Sibonelo
I had a similar issue on my 530i, replaced the disc with aftermarket. lasted 1000km and the shudder was back. went to Tune Tech and they advised OEM discs. They experienced it many times where the aftermarket discs have a shudder. maybe they not balanced or whatever I don't know. bought BMW discs and didn't have the issue..
I have always stuck to agents brakes but the front discs and pads on my F25 X3 30d were coming to around R9k which I found ridiculous.
I decided to go for Stone discs and agents pads instead.
Still early days but will update if I get a shudder or any issues with the cheapie discs.
