Shuaib E36
Hi all, I’m having a problem with my E36 (4 door) lighting. My headlights and brights work perfectly but my driver’s park light does not work all. It’s the same on with the driver’s side tail light, reverse light and indicator light work but not the park/brake light. Any idea what it could be?
I’ve done all the pre-checks - bulbs, fuses, relays, bulb holders at the rear, etc. I’m yet to check wires in depth but so far nothing looks frayed or damaged.
(Also there’s a hefty wiring problem on car which I’m going to sit with in due time, for example the car stays running if the lights are ON and low beams don’t go ON unless fogs are ON. I’m not sure if this is a contributing problem considering the left side works perfectly)
All help will be appreciated, thanks in advance.
