discussion E90 323i auto 2010 bad diff - swop out
Ash_e46
Hi Guys,
Hoping someone, anyone could extend some advise.
I recently purchased a e90 323i 2010 with about 150k on the clock. The car is in good condition however I have a grind on the diff which has been deemed bad diff. I am looking to replace the diff but can't find any 323i diffs in Cape Town. My understanding is that they all differ in e90 series.
Can I use all alternative diff? If so, which one? I have an auto which has 3.73 I may be wrong.
I'm desperate and don't want to pay 15k to refurb as my research shows this is a design flaw.
Ash_e46
Hi Bud.
The 325i auto also uses the same 3.73 diff.
I had mine removed a while back for some work and I can confirm it was a 3.73.
Thanks brother.. Forgot to mention, mine is an LCI. This makes no difference right?
Stripping it out the weekend so I can have a physical sample
husaindindar
It should be the same...
Also, have you made sure its the diff that stuff'd?
Its not a high powered car and the kilo's are quite low for a diff to go bad.
Maybe make sure its not the universal joint or the centre bearing.
I had a vibration that everyone told me was the diff. It turned out to be the rear univeral.
Ash_e46
I'm experiencing vibration and grinding noises from the rear. When the car was jacked, saw it's leaking from the diff. Those are the only tell tale signs
