Ehm no, technically, there is no recuperation via brakes - this is only possible when an electric motor drives the wheels, so the motor can be used to brake the wheel and store energy. It is more an intelligent alternator strategy, specifically designed to use peak charging when on the over-run and braking. Over-run being the key to switching to maximum charging.
It basically means your alternator only charges your battery when you are decelerating and wont add load to your engine while accelerating. There is no recovery from your brakes
Being a bit of a nerd, an average 12V car battery (100Ah) can store about 1kWh of energy. The kinetic energy of a 2ton car moving at 120km/h is about 300 kWh. So this clever alternator strategy at best, can recover 0.3% of your kinetic energy if the battery is flat and you slow down from 120km/h. So it really doenst make much of a difference, but a small amount consistently can add up I guess.
The above assumes I have mathed correctly (highly unlikely)
