The General's F13 M6 Coupe
swazi85
Morning kids.
Small update, havent done much to the car. but a few small things.
I purchased 2 Brand new Bosch Primary O2 Sensors (Wideband). i havent taken any photos of them so will take a few pics of the old O2 sensors when i can, they actually not bad at all.
I realised i needed the O2 Sensor socket, so contact @Bugger and he loaned me his one, so much appreciated to have the right tools (I must still make a plan to come return it bud.)
The O2 sensors were changed in under 5min, was very quick, and the car felt a little smoother, however the voltages and values when logging read the same, so safe to say the refresh of the sensors wasnt needed, but always good to have new i guess, but i have a spare set if i ever need them now.
Also i got the OEM Downpipes from @swazi85, was a pleasure to meet you man, and the F90 looks good in the flesh.
I then also tackled the disconnection of the Comfort Access handles to try diagnose a battery drain i have, after 2 weeks or more, i still have the same issue, so its safe to say its not the handles, so when i have a gap i will be reconnecting them (Yes i did clean the grime that you see there):
The 4 wire connector was for the Comfort Access, and the 2 Wire connector is for the LED Puddle Light, so quick and easy test. just finicky.
So i believe the issue has to be a forgotten Tracker unit somewhere in the car, i just need to spend some time and strip out all the engine bay covers, Footwell covers etc to try find the damn thing and remove it.
My battery health on the Bimmerlink app shows as 55% fully charged (on an apparently new battery), but within about a week, its dropped down to about 41%, and slowly gets lower.
Also, as the battery drops and gives me "Charge Battery" errors, it starts to affect the car, like causing Rail Pressure Sensor errors and then the car runs badly till i clear the error, i was worried about the HPFP going bad, but there is no way they both fail at the same time, and since keeping the battery at a decent level of charge, the Rail Pressure errors havent returned, so i know for a fact its the battery causing it.
So requirment is to buy a new OEM battery, or, at the very least, buy a new Varta AGM 105aH battery, as they are the OEM supplier. I have a First National Battery currently fitted, which i think i got screwed on. but it is what it is.
Some things i want to fix that are bothering me a bit, but not a major issue:
1. The coolant hard lines running to the turbos are sitting a bit higher than they should, and i see that its because when they rebuilt the motor, it looks like they werent routed perfectly, so instead of slipping under one of the lower pipes, its resting on top, and keeps the pipes lifted. so ill tackle that when i replace the Auxillary Coolant pump under the Charge Cooler.
2. Change the 4 rubber Coolant Pipes and Heat blankets by the turbos as preventative maintenance, pretty cheap from BMW.
3. Maybe new Charge pipes, as the locating clips for the Coolant hard lines are broken, but its not a major issue, ill assess once i eventually fix the routing issue on the coolant lines.
Also since the Software update from BMW a few weeks back, i lost all my coding i did to the car.
So i redid a few things:
Turn Signals on HUD
Entertainment info on HUD
Navigation on HUD
Lane Assistance on HUD
Comfort Closing Delay disabled
Easy Entry on seats activated (Moves the seat back when you switch the car off so you can get out and in easier, and puts the seat back to the Memory position when you Close the Door and put IGN on again. )
Easy Entry for Steering Wheel activated (Moves the Steering wheel inward, and then upward to help make space for exiting and entering the car)
There are a few more tings id like to play with, but for now thats all i need really, the Easy Entry has been the nicest addition, now i dont have to rub the side bolsters when getting in and out.
Also, i sorted the Seatbelt issue where it doesnt retract, i pulled them out completely, quick rub down with a microfibre, then sprayed Silicone Spray very liberally on the belt, and inside the mechanism as i was feeding it back.
Both Driver and Passenger belts now retracted and feel like new.
Shot everyone, so far, im enjoying the hell out of the M6. :D
Glad the down pipes will help you out bud
Howsit all. So another update.
One I've been sort of watching for about 6months and finally pulled the trigger.
On FB Market Place I came across a full M6 Competition exhaust. This was around 6months ago. Eventually, this past Monday I still saw it available, so I offered him a ridiculous price for the exhaust, telling him that either he accepts it, or he can sit with the exhaust for another 6months, as the M6 exhausts aren't really flying off the shelves.
Anyways. He accepted and I had it collected by an exhaust shop (Tyres and More in Alberton), I then arrived this morning to have it fitted.
My exhaust is as you know the basic standard M6 Exhaust, the differences between the two are small.
Standard:
1. Regular back boxes with baffling
2. Silver tips
Comp exhaust:
1. Titanium Black tips
2. Less Baffling in the backboxes.
When I arrived the Exhuaust was waiting for me, still with the tips and the front openings wrapped up by the seller.
Car got on the lift and we started removing covers, brackets and bolts etc, and the old exhaust came out.
New exhaust went in easily, no issues at all. I bought new OEM DP/Exhaust gaskets and seals for the install today too. And the tips are dead straight and line up in the diffuser perfectly.
I am very happy with the look, and the start up has a nice deep tone, I can hear the difference from stock to Comp, it's not overly dramatic. I'm still yet to have a cold start which I'll do tomorrow morning, but I don't think it will be stupidly loud, even with the downpipes.
The car also starts up smoother, and I think this could be down to the old exhaust having a leaking gasket between the DownPipes and the Exhaust connection.
Might be placebo effect, but the car does feel somewhat smoother on the drive. Whether it's related at all. No idea.
The exhaust tone MIGHT change slightly as the exhaust gets a few heat cycles, but I'm not sure if thats related to new exhausts only. But this exhaust was apparently removed off a M6 that had only 25 000km on it.
So guess tomorrow's cold start will be an interesting one to compare again the old exhausts cold start.
I'll let you guys know the outcome.
But Im happy with the look and tone of the system now. Especially with the down pipes. No drone whatsoever, just a good deep rumble at idle. It's lovely.
A few things I noted I need to attend to.
1. My one controls arms bolts are switched around, the short one which should be wheel side is on the subframe side, and long is by the wheels side, so I noted it connects the caliper on full lock. So need to get them swapped over.
2. My drivers side rear axle seal is leaking by the diff, as the side shift connection is wet and grimey, so needs to be replaced.
Other than that, the car is still bone dry underneath, no signs of leaks of oil, coolant, or anything. I'm very impressed.
Car still smooth as hell and I'm about 12 000km into the rebuilt engine.
So far so good.
@FiRi@Rennzport I do still want/need to order black grilles from you, which I'll arrange when I can but will communicate privately. But you'll hear from me.
Thanks all for reading.
GravityLee
I was driving in front / next to / behind you (in that sequence :D ) on Main Rd this past Sunday. Car is looking awesome, and converting all the fuel into some very decent noise. Must be even better now.
cRed001
Nice find on the exhaust. Car is looking good. A nice small mod would be to remove the rear number plate holder... unless you own the dealership.
Yea I've been meaning to do that and just get regular license plate holders so I can get rid of the dealership name.
Bugger
Got a Cold start this morning with the new setup. Has a good tone, pretty loud on initial startup. And settles to a great deep tone on Idle.
This is becoming a proper windgat car this. Such a pity...
Just kidding man. Car really is looking good bud, making me jealous, and regretful, I'm going to do something silly now. I can feel it.
Just wait, I saw a big wing at Boksburg fleamarket, and some Anime decals, and chameleon window tint. It's gonna look the business 🤣
Just kidding, thanks man, yea so far so good. I can see a M back in your garage again soon too
Gordvisr
Have you tested the charge from alternator ? Do you get the drain battery while driving or only on start up ? If while driving, best to test the charge from alternator. I bought a relatively cheap multimeter to check voltage when i had some issues , ended up being worn brushes on the voltage regulator. on the multimeter before the change the charge voltage was erratic, at times below 10 volts and at times higher than 15.
After the change the voltage was at steady 14.8.
Thanks man. No I never get a battery error while the car is running.
Battery voltage while engine is running is between 13.8 - 14.4v depending on load and accessories switched on.
I'll get the Battery Discharge when Stationary error sometimes.l when I start the car. But doesn't happen often.
But if I don't put my car on charge for around a week or slightly more, then I get Charge Battery error when I shut the car down after a drive.
Also my car does mainly short trips, around 7km (15min) one way to work. And the same back home in the afternoons. Sometimes I do long drives on the weekends. But currently not many.
Bugger
You're going to have to check for that dormant tracking device, that's what was pulling the charge out of my battery on my GC, so even after the car sat for a weekend on a charger after two days I got battery issues back. And yeah it's a PITA cos it does definitely affect a lot of aspects of the car, amazing how hard they are on batteries with all the electronic components. So there's a little devil lurking in there somewhere, all you'll do is continue replacing batteries!
Thanks man, yea thats what i want to avoid, dont just want to throw another new battery at it with the same results. really need to go through this car with a torch and a fine tooth comb, front to back. there has to be one there.
Hi All.
Not much to update here, as ive just been enjoying the car.
Still be trying to track down the possible battery drain source, still no luck, so a couple weekends ago i decided to strip all the plastics off the engine bay to try find anything that may look like an aftermarket device, and i found nothing, so saw how dirty everything was, so took the opportunity to give it a clean, will do it again at some point with some engine cleaner/degreaser, a brush, and the pressure washer. but for now, its better than what it was.
Before with Plastics stripped
After a quick clean:
I cleaned the black plastics also by the headlights, but need a good brush and some detergents for a better job, so will strip off again later on.
And then just some random shots of the m6, i went to Visit my dad as he bought a BMW RT1250, so went for a ride which i was very impressed with:
Thats all i have for now, nothing major,
Thanks all
Bugger
The car is looking good J. We NEED to get that beer! Sorry I've been quiet, new job and all that has been keeping me pretty honest.
