It would be good to take off the cover under the bottom of the engine area and check for oil leaks. Sometimes it is just a little leak that doesn't register on the computer.Yip, I recon spending R15k for the warranty for R50k cover ( shortfall if any) is better than no warranty and R50k + shortfall if any.
On the topic of preventative maintenance on the B58...car is on 80k km now. Up to now I've only done scheduled services. My plan is to add the in between oil services going forward plus a ZF service and diff oil change now when it comes out of plan in Aug (I don't think the extended warranty company will mind the gearbox and diff service). Anything else preventative guys?
Another topic, car will go in for a few items while under plan still. Anything else you guys can recommend I can ask them to check?
My list:
Right rear door lock (faulty)
Door rubber creeks
Bushings and mountings
Coolant system
Shocks
Full suspension check (control arms, tie rod, etc).
Brake pad and discs check.
Engine/gearbox mounts
Propshaft check
Main battery check
Aircon gas check
That's all I can think of now.
