There I fixed it for you 🤪Adnins, we need a special title for guys like Benji on this forum.
"Well Known Member" should be upgraded to "Blood, sweat and beers Fanatic", or something like that.
now that's what I call a productive weekend.Thank you for fixing that important detail, beer lubricates high quality work
Found this pic after a typical weekend of work, you could play a game of "count the bottles"
Looking good, thats the unt I want, not really a fan of the ipad type ones. There is another one with the buttons on the bottom which also looks good.My chinese android radio finally arrived after delays from Alibaba, applying for a refund and then ordering from Aliexpress instead.
I am so far very pleased with this unit, it looks OEM and works as OEM with the added benefit of Andoid Auto (soundcloud, spotify etc), Google assistant, 128 gig onboard memory etc. It even has the useless ability to mount a SIM card so I can make the car a wifi hotspot.
All nicely mounted with the proper HVAC relocation bracket which is in much better condition than my old one. I just need to mount the USB ports properly so that it all looks OEM:
Yeah same, I think this is the most OEM looking unit available:Looking good, thats the unt I want, not really a fan of the ipad type ones. There is another one with the buttons on the bottom which also looks good.
Can you share a link for the one you got?
CHSTEK Qualcomm 8+128G Android 11 Car Radio DVD GPS Navigation For BMW 3 Series E46 M3 1998-2007 CarPlay Head Unit Auto Stereo - AliExpress 34
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
I ordered 2 units from the same supplier, one came via PO, one came via Fedex - weird. The PO one was about R80 in destination charges, Fedex wanted closer to R600, annoyingly. Both came in the same week, about 2 or 3 weeks after orderingHey Benji, how long did the headunit take to arrive? Guessing it came via the PO?
5mm # 33 53 1 136 385What thickness spring pad did you go with?
You got a part number handy?
Ya was also planning to double up.5mm # 33 53 1 136 385
7.5mm # 33 53 1 136 386
9mm # 33 53 1 127 224
10mm # 33 53 1 136 387
14.5mm #33 53 1 094 754
When I said "adding a thicker springpad" I meant I a spare set of stock (I believe 5mm) pads lying around, so I just doubled up the top spring pad with some modification to make sure they located properly![]()
I have done a thing...
A rather quite tasty set of E90 Sport Edition 18" Style 216 wheelsIve been searching for a set for a couple months now and made this happen with scouting help from a forum member, convincing someone to swap the wheels on their car with normal 18" M-sports, frantic searching for said M-sport wheels on FBMP, driving out to Lanseria to collect said wheels, driving to Lenasia to swap the wheels in the dark on a Friday evening in front of a bemused household. Worth it? Probably. I initially decided to run 17s as this is my daily and it should remain comfortable, but a daily is the one you see the most so should also be the coolest car, right? Anyway, currently running RFTs and the ride is surprisingly not noticeably worse. Win!
I also lifted the rear slightly by adding a thicker spring pad - this car is running OEM sedan 325i M-sport springs, so the rear was sitting a tad lower than the front and I didnt want to lower the front any more as my floor has been making too much contact with mother earth and all the speed bumps designed for Ford Ranger drivers.
Car is ticking along nicely and regularly returning 800km on a full tank, I need to do the 10,000km oil service as a matter of urgency now. Oh, I also need to wash the car, I am fairly embarrassed to say I have washed it twice in my 6 months of ownership. The petition for a 3 day weekend starts here...
I have a "set" of 3 wheels I am trying to get rid off...car looks great!
if you ever think of selling those wheels..........shotgun! thanks.
