Are there actually petrol stations that sell 98?
you buy it in drums
always thought it would be great to have 1 pump with 98Are there actually petrol stations that sell 98?
What does a 20L can of each (24/7RF & BP) cost? Reseller prices available on the web seem steep AF @ R65/litre.
Is there a particular reason for throwing in the ethanol first?Breaking it down: Add 5 litres of ethanol (E95 or E96) to an empty-ish tank before filling up. Depending on tank size and level that should give you between 10% and 12% mix. I use about 5litres on every tank and top ip with between 42 and 45 litres of 95. JB4 Map 1 with no knock retard / issues.
Buying the metal containers is a PITA. You need a syphon to use those without messing. I usually just transfer the ethanol from the can to a 25 litre plastic container as those are easier to decant into a measuring bucket, from there to a 10litre fuel container, into the boot, off to the pump.
It's probably safer than trying to mix ethanol and I've read that some of them do have cleaning properties like OB1. In saying that, it's more expensive per litre to run.Interesting read on ethanol. Any thoughts on the off the shelve octane boosters?
My understanding is that it helps it mix. A couple donuts or figure 8s might mix it just as well.Is there a particular reason for throwing in the ethanol first?
I'm interested in running E10 in my car but would it not be easier to fill up at the petrol station then top up with ethanol at home?
You make a good pointPouring 5L/10L in at the petrol station is not really a big deal. You're going to be driving to your house from the petrol station with different fuel to what you drove in with.
I think OB is still the way to go.
I've used LiquiMoly Octane Plus a few times, each time switching MHD from 95RON Stage 2 to 98RON Stage 2+, without any timing pull.
At the current price of R184/150ml, which lifts 50l of fuel by up to 4RON, it only adds R3.68/litre. Much cheaper than going for the 98RON premix, even if you put in TWO cans OB for peace of mind.
Does it not come at the expense of extra wear on plugs and deposits in your exhaust etc like NF does? That does seem like good value
Damn, I didn't know about LiquiMoly Octane Plus - that is insane value for money!I think OB is still the way to go.
