E83 04 turn signal
getty150
Anyone aware of the location of the turn signal sound, the tic-toc when turn signal is activated. The blink light indicator works. Its the sound... goes mute from time to time. Seems as though the sound comes from behind the dash?
getty150
Cluster....dead!
Made my way to the car salvage yard, was able to pick a cluster from a donor car...still needs to be coded/programmed with the correct vin.
getty150
In my research (mo's ago) I read that for the 04...if you use a cluster from another 04 the situation would be plug and play therefore no coding/programming.
Can any one verify.
An 04 just arrived at the boneyard.
getty150
Can any one verify.
Not true...not plug and play...new vin will needed to be programmed in.
sash
I know on the older vehicles it was on the hazard switch, but no idea on the newer cars. Did your entire cluster go dead eventually?
