Thanks! The quote is from BMW Midrand, miss that BMW Fanatics discounts though 😊Which BMW did you try for the pricing specifically?
Call BMW Midrand, chat to Deago in Parts.. They are best in pricing compared to all other BMWs.
Thanks for this information!If you're feeling brave, you can attempt a DIY rebuild on the HPFP. I have done this on mine, and it has been 100% since. The hpfp is filled with hydraulic fluid, which leaks out over time. (usually via the rotary seal) There is a step by step process of refilling the pump, and replacing the seal.
There are obviously a few ways in which these pumps can fail, but most of the time, it is due to the fluid leaking out.
I see that the online guide has now been password protected, but have a look at my post over on spoolstreet, for a rough guide:
https://www.spoolstreet.com/threads/please-review-log-hpfp-failure-or-something-else-solved.9048/
Post #4.
Good luck!
I was lucky enough to have one lying around, but most seal companies should stock them.Thanks for this information!
I have been suffering from a failed HPFP as well and have been looking for information on re-building these pumps as an option. If I may ask where did you get a new seal?
*Sorry for hi-jacking this post but I thought gathering more info on this thread will help everyone more rather than starting a new one
Thanks for the heads up, sucks it's not a simpler solution as it would have been alot more popular especially as these have, gotten rarer to come byGuys, some feedback from me.
I have two non functioning HPFP's which is used to try and rebuild. And in summary - don't waste your time, buy an original from BMW.
I tried rebuilding these pumps a few times over with different methods and could not get them to work. For a number of reasons I can mentions below:
Honestly I believe I did everything I possibly could to give this a chance taking special care but it does not seem possible. I personally think the issue still is the o-ring size is not correct.
- The o-rings I believe are not the correct size. No matter what I tried the o-rings would get pinched when installing them and that would result in them not sealing obviously. I tried different lubes. I tried turning them in slowly. I tried turning them in quick. I tried heating the housing and freezing the bellows. All of this did not work.
- I even tried a few similarly sized o-rings from BMG and could not get them to seal.
- The shaft oil seal should actually be 22x11x7mm and not 10mm. This seal works fine but the issue is sealing the unit with oil after wards.
- I tried both Freakoids method of filling with oil while applying vacuum to the diaphram and even submerging the whole unit in oil and bolting it together.
- It all looks promising at first - the diaphragm showing showing 16mm vs 27mm - but after rotating the shaft a few times the oil starts coming out the high pressure fuel side and the diaphragm quickly returns to 27mm indicating failed o-rings.
Its a very messy job and I gave up and got the right part from BMW.
I still have these two failed pumps that I might have another crack on with some other o-ring sizes to see if I can get it to work but in the mean time this was a failed attempt.
ah man, sorry to hear that. I guess I was lucky enough to not have to change the internal o-rings that seal the bellows!Guys, some feedback from me.
Yeah man it could be a really nice DIY solution to an expensive problem.Thanks for the heads up, sucks it's not a simpler solution as it would have been alot more popular especially as these have, gotten rarer to come by
Hello AllReviving this, with a bit more info, and a bit more personal experience.
A while back my rail pressure was starting to falter again at WOT. After measuring at the diaphragm, I was back to 27mm. After I removed the pump, I noticed that the new rotary seal had been completely pushed out by the internal pressure of the pump. I had a local engineering company machine a slot/groove to take a circlip, which now firmly holds the seal in place. Almost 1000km later, and rail pressure is perfect.
PDBoosted is indeed correct, the shaft seal is 22x11x7mm. Regarding the seals for the bellows, it seem(after some more research) that X-rings are not the way to go, as the seals get pinched while re-installing, and that causes further leaks. A standard O-ring is the way to go.
Size: 20.35mm(ID) X 1.78mm - It's worth noting, that the usual failure point is the rotary seal. So if you have no fuel inside the pump, there is no need to replace the seals for the bellows. If it ain't broke, don't fix it.
Rail pressure is now happily at 2550-2700psi at WOT.
*I tried to upload a pic of the pump with it's new circlip, but for some reason, the site is not letting me do that today.
I have a PWG N55. So not the same, of course, as yours.Hello All
Apologies for resurrecting an old thread . This is the current situation....
My N54 335i with 127k on the clock and FSH has an HPFP that has failed ( diagnosed by BMW ). Quote from the dealer is R20683.00 vat incl for the pump only. I have tried to source a non oem part and the only suppliers out there that seems to be able to obtain one is GW and Midas, a MotoEuro brand R8k vat incl.
Has anybody used this brand of HPFP before and whats the longevity like?
I have located an independent tech who has a workshop at his home that apparently recons these pumps for BMW and Mini dealerships (so he says) all over the country. Total cost of recon is R4500 with a 12 month warranty with a 5 day turnaround time.
Should I take the plunge on a recon unit or fork out the R20k for an oem unit ( with a terrible feeling of being ripped off )
Appreciate your views on this .......
An important question too is, is it stock, and do you only run pump fuel on it? OEM pricing is on par I believe, nothing weird there.Hello All
