Hi!Why not just leave the pipe in the block ? Just replace the o-ring on the side that goes into the new turbo
So this Afternoon I went to BMW to find out some costings on the pipes and O-RingsIf the pipes are not too expensive maybe it will be less frustrating just to cut them and but replacements.
100% agree on oil services and maintenance , Sadly in this case , the turbo failed just 2000km after the motor plan ended . We had to keep to the BMW oil change schedule which is horrendous , I generally change the oil, and filters on our cars by myself by at least 5000 to 7000 km . But on this car we couldn't do much .more reliable is to take care like previously mentioned, regular oil service also plays a role. make 100% sure the oil feed pipe is not clogged up. Oil starvation is a big turbo shaft killer. Most turbo repair shops will give a guarantee only if oil feed and return lines is also replaced with OEM units.
Not sure who is the go to guys down in Kzn, maybe someone on the forum has some insights.
watCar was just off motorplan so the cost to replace the turbo was to much , We ended up buying a new car and this has been parked in the garage ever since .
@zippy320 - just check those sensors using Real OEM as from my experience one will be for cylinders 1&4 and the other will be for 2&3, you will be able to see using the colour of the cable.Thanks @DarrylvanNiekerk , I cleaned them up , they do look pretty new now , used a generous amount of parts cleaner and buffed it with the rough foam thing of the dremal tool . When everythings reinstalled , I hope I dont end up with any error codes.
This car seems to have two different sensors , one has a black wire , which is attached before the cat , the other is a grey wire which is after the cat . Prob to detect before and after .
They cost around R1400 new each from Goldwagen for the Bosch parts . Parts prices just seem to add up on this car lol
Hi @DarrylvanNiekerk@zippy320 - just check those sensors using Real OEM as from my experience one will be for cylinders 1&4 and the other will be for 2&3, you will be able to see using the colour of the cable.
You will still have downstream O2 sensors after the cats and those have different plugs.
The plugs are the same on the upstream sensors (at least in my case they were) and I battled to figure out which plug went into which connecter when reinstalling.
I had a bit of a misfire so used a scanning took to check live data on the sensors and found the readings were mixed up. Once they were plugged in correctly my Lambda readings were at 1 across all cylinders.
@Solo Man , Im a bit worried about how the car will behave , I was told it uses these sensors , before / after to measure the fuel to air ratio and that would affect economy and power .On my diesel i do not find the car any noisier than before since removing the cat and putting the empty box back on the car. My car also do not have any sensors either before or after the cat so cannot comment on that. I would think that you could get away with it but should you get an error light you could have it coded out. Car should run slightly better without cat anyway.
@zippy320 - the cat is a simple delete (keep the fitting in place for correct air flow) and can be coded out but it is safer to keep the O2 sensors active so the engine knows what is happening fueling wise and does not run with default settings.@Solo Man , Im a bit worried about how the car will behave , I was told it uses these sensors , before / after to measure the fuel to air ratio and that would affect economy and power .
On most engines, the feed pipe start clogging up, even with regular service intervals, mainly due to the thickness of the pipe( especially through the flex part ) and not to mention the heat it is exposed to being close to exhaust manifold, same happens with return pipe. The price at BMW for the feed pipe is actually not that bad considering the cost you might have to go through should the turbo fail again.What else would cause a severe lack of lubrication ?
