You guys might remember this grey E46 M3 from a few years ago on the forum. π€£ Well I bought it last week without seeing it. Took a risk at a very reasonable price. Expected a heap of a project car when it arrived on the rollback.
Turns out a couple of hours in the workshop sorting out some hack fuel pump wiring issues (faulty Relay, yet someone decided to hot wire the pump to bypass it... go figure), ignition switch (again was hot wired when all it needed was a new switch that cost a couple hundred bucks), removed and correctly reinstalled radiator, oil cooler etc. Replaced some parts very cheaply. Fluid change (no iron filings in the oil), new plugs and filters. New maf. Regas aircon.
Started her up and surprisingly, no Vanos issues and engine is smooth and quiet. Gearbox fine. Diff groans on slight turns. Hoping that's just a need of Castrol SAF-XJ and some tight turns to free up the clutches. Undercarriage is rot free. Diff mountings already strengthened and no signs of cracks. I need to source braces ..waiting for Ultra Racing to get back to me on aftermarket pieces. Underside will need a good clean and sealer. Seems like it's been standing for a while... dead spiders and dried wasp nests. π
Put on some wheels I bought of the forum years ago. And drove it around the block a few times. Shocker....Turns out, a usable car with a smooth drivetrain and fresh interior. Cost me faaaar less than what guys are buying E30's for these days.
Still needs work but hey, this one is satisfying π.
