Just get a raspberry pi 3 off Carbonite and make one yourself. You might need to be a bit patient for one to come up. Once you have it, It’s easy. Just flash the image onto the SD card and away you go. If I find a spare I will DM you.
Thank you so much for the info. Another question please, does it work when you plug in an Ethernet cable to your iPhone using a Ethernet-lightning adapter?
I have never tried this. I've only used this on a laptop or via the Wifi/Raspberry Pi. It is very dependent on the adapter you get though and some of them are hit and miss - check the forums/facebook page for protuning freaks to see what works. Been a long time since I used it so compatibility might have improved since then (I had BM3 last on my F10)
