Hey guys, first post here so here goes. Have a 1992 e34 M5 (s38b36) ,car was a barn find but in generally good shape, however she has some strange issues.
Issue #1: Car hunts for its idling point when warm (revs gently between ~600 rpm and 1000 rpm without any throttle input) . Doesn't do it when cold.
Issue #2: Car starts to hesitate/bog at around 6000 rpm for a few seconds and then pulls through to the redline. However, it only does this when you pin the throttle. If you roll onto the gas slowly it doesn't hesitate. Also have intermittent popping under compression. Replaced fuel filter and no luck, so maybe bad injectors or fuel pump?
I have checked that the resonance flap doesn't self test at start up so that could be adding to the problems. However, the actuator doesn't seem to be the issue since I connected a line to it ,sucked on it and it worked (so I'm thinking bad solenoid or vacuum leak?) all the hoses seem fresh though.
The car is going into the shop early in the new year, so will get them to check all the vitals (fuel, air, spark and compression test). Overall I'm left feeling a bit despondent with the performance. I realize its an old+heavy car and not that torquey but honestly thought it would feel a bit more alive, my dad's 1969 E-type feels way stronger haha. Does anybody know a reputable mechanic/garage in the Western Cape that works on these older m cars? Any advice would be greatly appreciated. Will report back with info as I go along.
Thanks in advance
Thanks in advance
