individj said:i think he is on the forum...Mo? I saw they sold the Rezax
individj said:well its yours now haha get used to it...
so NA and a daily...i used to daily a 318i...it was pleasant but not quick at all....this was at the coast..
i mean at a lower budget you could do a branch and exhaust with a cam reprofile and make sure its in good health before obviously...make sure it has good compression on the cylinders...
If it needs rings etc. then you could probably look at doing more...to raise compression and do a more aggressive came and possibly ITBs
Personally...if it were my car...id drive it as is and build up an engine on the side....2.7 M20 or even 3.5 and drop that in a a year or 2 with everything needed...
What i will say is have a good think...think about whether youll keep it forever too..
Make up your mind and stick to it...ive destroyed budgets by moving the goal posts either mid build or after its done...
juice4434 said:individj said:well its yours now haha get used to it...
Howsit mate
Trust you well and safe
Having done quite abit of amateur research seems it would make more sense to do an engine swap both for value for money and effectiveness. I will find someone in RSA to do it for me if I go ahead but what advice can you give me in terms of NA engine swap, what engine ? Estimated costs well as what would be involved.
Car is intended to be used as a daily mainly
Look forward to your ideas as usual
Stay safe
Im based in Malawi , there is total trust , passion and honesty in how they work , every penny was accounted for through the build , really very rare to come accrossWow looks like a different car! Congratulations!
carcandyinc are definitely doing a great job sourcing and selling E30's and rare parts for them from all the posts I see on social media! Well done to them!
Amy further help on this guys ?Hi Guys , was looking for your wealth of advice. So my build is finally complete and car delivered to Malawi. The engine was changed to an M20B20 with a custom exhaust that sounds phenomenal, however I do find the power of the M20B20 a little lacking. I would like to add some more punch and have been advised to consider a UniQ or Dicktator. I need something relatively simple as mentioned before there is a lack of mechs I can trust with this job here in Malawi so plug n play is the easiest way forward. Credit to carcandyinc for the most professional job 👏
only saw this now! So this was your car! looks great...does it have on an exhaust manifold? I wouldnt do management on it...would want the stock ECU...if it doesn't have a mani i would imagine and camHi Guys , was looking for your wealth of advice. So my build is finally complete and car delivered to Malawi. The engine was changed to an M20B20 with a custom exhaust that sounds phenomenal, however I do find the power of the M20B20 a little lacking. I would like to add some more punch and have been advised to consider a UniQ or Dicktator. I need something relatively simple as mentioned before there is a lack of mechs I can trust with this job here in Malawi so plug n play is the easiest way forward. Credit to carcandyinc for the most professional job 👏
