what is the spread pattern like of those led fogs? I couldnt figure out what would work good for fogs when going LED. So really curious.My E46 OEM xenon ballast was on the way out, it would power up but switch off after a minute. Also got shocked to see the price of R8k and importing would mean no real after sales support, should something go wrong.
Visited Jabsport last week and he sorted mine out by using his own ballasts and igniters, works a charm now. I even did LED fogs to match the xenons and it still worked out to less than importing 2 ballasts.
@Tinuva the LED fogs are bright AF. I was able to drive at night with just the fogs and angel eyes, which was still better than my halogen headlights + halogen fogs. With the xenons on as well, I daresay the total light output is even better than the other cars.what is the spread pattern like of those led fogs? I couldnt figure out what would work good for fogs when going LED. So really curious.
The best ones are those morimoto something like that, but they work specifically on the M3 and/or the mtech2 bumper. Still trying to figure out if they can be modded for mtech1.
I only fitted them on a few weeks ago and used the car a handful of times, with zero fog here in Durban. I can confirm that it seems to disperse a wide, low beam compared to the xenons, but will revert when I eventually experience some fog.Ok but fogs is not about how bright they are but how they assist you when there is actual fog to see the road surface directly in front of you. Should be very wide and low where normal lights are less wide and reach further. There is reasoning behind how fogs should be different to low beams like low vs high beams.
Sent from my Mi 9T using Tapatalk
ok fair enough. We do have fog here quite a few mornings so thats why I am interested.I only fitted them on a few weeks ago and used the car a handful of times, with zero fog here in Durban. I can confirm that it seems to disperse a wide, low beam compared to the xenons, but will revert when I eventually experience some fog.
I just like the way it looks with the angel eyes on.. Rear fogs however will only ever be used in poor weather situations.
Well your xenon's pattern at least is perfectly alignedThis is the only pic I have of the xenons and led fogs off hand.. View attachment 4864
Haha, I am pretty chuffed tbh, that pic is with the area in darkness. I feel like I need to adjust my xenons though, as they throw too low/close to the bumper.Well your xenon's pattern at least is perfectly alignedIs all I can see from that. The fogs probably need to go wider for real fog usage.
