S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Ten - Assembly Clocking rings and the separator for the oil ring. Unpack the wrapped block Unwrap the cleaned crank I...
Oct 5, 2026
R
raks16
reacted to
M3boi's post
in the thread
My new little venture - DriveStudio
with
Like
I've been a little quiet on the forum, and part of the reason is because I've started a little business called DriveStudio! After...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Nine - Measuring Things Main bearings measuring right in between tolerances The big end measured fine as well...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Eight -The Cleanup and Cylinder Hone Start cleaning the crankshaft and oil squirters Once the varnish is removed, the crank...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Seven - Vanos I looked around a bit and did end up with a seal kit from Beisan Systems, I didnt have any rattle issues so...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Six - Rings, Bearings, Oil Pump etc. Since the rings were the source of trouble since new, I was determined not to use the OE...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The 5th Gear Lean This car came equipped with the five-speed manual ZF gearbox; at some point in my ownership of over 20...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The Engine Teardown Vanos Removed The dual mass flywheel wasn't in bad condition but LUK clutch and flywheel...
Oct 5, 2026
reacted to
Spanky's post
in the thread
Spanky's E82 135i DCT
with
Wow
So, I've undertaken the painful step of cataloguing all expenses incurred on the car to better understand where I stand with it. I track...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Three - Engine Removal Remove Intake, Exhaust Manifolds Remove the drive shaft bolts on the gearbox side from the flex disc...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Two: The Side Quest What really took care of the road for a week or so was a failed water pipe. I had changed the main radiator...
Oct 5, 2026
DINODENASH
reacted to
TheFlash's post
in the thread
technical
with
Love
Chapter Twelve - Engine and Gearbox Back In After giving the engine bay a good cleanup, the engine was dropped in with the gearbox...
Oct 5, 2026
replied to the thread
This is fantastic bud! Well done for identifying a gap in the market and taking the leap to fill it! Around 15 years back my ex...
Oct 5, 2026
CinZano
reacted to
TheFlash's post
in the thread
technical
with
Like
Oct 5, 2026
reacted to
M3boi's post
in the thread
with
Like
Oct 5, 2026
