reacted to
M3boi's post
in the thread
My new little venture - DriveStudio
with
Like
I've been a little quiet on the forum, and part of the reason is because I've started a little business called DriveStudio! After...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter One - Tools to remove the engine Bolt-on supports for the jack stands; these help secure into the factory jack spots and safely...
Oct 5, 2026
Naruto
reacted to
Clint@MMS AUTO's post
in the thread
with
Like
TODAY’S UPDATE - REAR SUSPENSION REFRESH In my attempt to constantly make some kind of progress on the car whenever I get a bit of...
Oct 5, 2026
S
SrC
reacted to
TheFlash's post
in the thread
technical
with
Like
This is going to be a journey. Was originally intending to do some basic maintenance on my 2002 E46 330i. The original list - Sump...
Oct 5, 2026
replied to the thread
Spanky's E82 135i DCT
I don't even know who this is, sounds like a mate you met at the bonnie blue queue???
Oct 5, 2026
Tinuva
technical
Those gearbox mounts are amazing, I run the same ones!
Oct 5, 2026
S
SrC
reacted to
M3boi's post
in the thread
with
Like
Oct 5, 2026
DINODENASH
reacted to
Peter@AEW's post
in the thread
technical
with
Like
Bravo! Big End Bearing clearance is 0,030 to 0,070 typically so you are mid point which is excellent. Looks like a solid build!
Oct 5, 2026
DINODENASH
reacted to
TheFlash's post
in the thread
technical
with
Love
Chapter Ten - Assembly Clocking rings and the separator for the oil ring. Unpack the wrapped block Unwrap the cleaned crank I...
Oct 5, 2026
W
Woodies
reacted to
M3boi's post
in the thread
with
Like
Oct 5, 2026
DINODENASH
reacted to
TheFlash's post
in the thread
technical
with
Love
Chapter Four - The Engine Teardown Vanos Removed The dual mass flywheel wasn't in bad condition but LUK clutch and flywheel...
Oct 5, 2026
A
Anees
reacted to
in the thread
with
Like
Oct 5, 2026
Sibonelo
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Twelve - Engine and Gearbox Back In After giving the engine bay a good cleanup, the engine was dropped in with the gearbox...
Oct 5, 2026
T
TheFlash
reacted to
M3boi's post
in the thread
technical
with
Like
What a fantastically detailed project, thank you for sharing!
Oct 5, 2026
AdiS
reacted to
M3boi's post
in the thread
technical
with
Like
Oct 5, 2026
