reacted to
raks16's post
in the thread
BMW 3 Series (G50)
with
Wow
Feels like the Z4M Coupe ship has sailed š„². All the recent R550k+ listings I've seen still need bearings and VANOS done.
Oct 4, 2026
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Twelve - Engine and Gearbox Back In After giving the engine bay a good cleanup, the engine was dropped in with the gearbox...
Oct 4, 2026
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Eleven - Engine Timing and Getting Final Items Wrapped Up The plan was to get everything close to lined up and finalise in the...
Oct 4, 2026
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Eight -The Cleanup and Cylinder Hone Start cleaning the crankshaft and oil squirters Once the varnish is removed, the crank...
Oct 4, 2026
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The 5th Gear Lean This car came equipped with the five-speed manual ZF gearbox; at some point in my ownership of over 20...
Oct 4, 2026
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The Engine Teardown Vanos Removed The dual mass flywheel wasn't in bad condition but LUK clutch and flywheel...
Oct 4, 2026
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Three - Engine Removal Remove Intake, Exhaust Manifolds Remove the drive shaft bolts on the gearbox side from the flex disc...
Oct 4, 2026
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Two: The Side Quest What really took care of the road for a week or so was a failed water pipe. I had changed the main radiator...
Oct 4, 2026
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter One - Tools to remove the engine Bolt-on supports for the jack stands; these help secure into the factory jack spots and safely...
Oct 4, 2026
T
TheFlash
reacted to
AdiS's post
in the thread
Found this 2003 e46 330i Individual
with
Like
The 6 speed and updated HVAC controls and some other updates came after the facelift, from production date 03/2003 onwards. I _think_...
Oct 4, 2026
T
TheFlash
replied to the thread
I have a 2002 June E46 330i with a 5-speed MT. I think I have the same climate control as well; it's the first time I am seeing the...
Oct 4, 2026
reacted to
TheFlash's post
in the thread
technical
with
Like
This is going to be a journey. Was originally intending to do some basic maintenance on my 2002 E46 330i. The original list - Sump...
Oct 4, 2026
Sibonelo
reacted to
TheFlash's post
in the thread
technical
with
Like
Oct 4, 2026
Peter@AEW
reacted to
TheFlash's post
in the thread
technical
with
Like
Oct 4, 2026
Peter@AEW
reacted to
TheFlash's post
in the thread
technical
with
Like
Oct 4, 2026
