Z3 M Coupe ride height
tyu333
Hi guys
After changing every single rubber in the rear suspension, including replacing the shocks with Bilsteins of my M Coupe, I'm left with one small problem:
The ride height on the left rear is a bit higher than the right rear.
Could it be that I could have installed the spring the left upside-down? :fencelook:
Other than this the car :thumbs:
Can someone with a Z3 M Coupe please check if the ride height of the left and right rear are equal.
Thanks in advance.
GoCart
My M is level…. In its original state 42,000K in the clock.
You are still running the original springs right, sagging possibly?
I’ll be completing my suspension upgrade soon; this will include H&R springs, so I’ll check if there are any funnies.
Fordkoppie
All BMWs in SA are slightly lower on the right hand side.
No one really notices or cares
Herman - You just have not measured it yet
tyu333
:ty: So no need to worry
Now that you say it, I remember my e46 was a bit lower to the right.
GoCart
You’re probably right, I’ve just not noticed it before. Not too obvious I guess. :thumbs:
