Tried to find some info on this so as to not start a new thread but can't find anything. Basically, my Xenon left front has been giving problem for years now (intermittently works and then stops working). Stealership has looked at it multiple times and confirmed that it is not the bulb/ballast or ignitor. I have taken it to recommended workshop who has tried a couple of times. I purchased a ballast on my own but that also has failed to sort things out. My question is, is there a way to determine if the problem lies with the ballast or the ignitor or the wiring? Swopped the bulbs over and problem remains.
Basically either the light will not fire or it will lights up a couple of seconds after the drivers side light. Once lit, if I turn off and on again it is almost instant but still lags the good light.
