dvst8 said:Speed limiters still in place and the M3 was on that limiter before the 1km mark.
SherwinX said:Hey guys limiter is in place due to my stupidity. Hit the limiter at 967m, so I don't it it cost too much. I think 275 is possible, maybe 280 if I use launch control. 270 was done with street tyres, no launch.
1/4 mile also learnt a lot today & ran 0.4 seconds faster by fixing the belt slip & not using launch control.
George Smooth said:SherwinX said:Hey guys limiter is in place due to my stupidity. Hit the limiter at 967m, so I don't it it cost too much. I think 275 is possible, maybe 280 if I use launch control. 270 was done with street tyres, no launch.
Was the difference in boost pressure measurable running at ODI with the slight altitude change?
George Smooth said:Was the difference in boost pressure measurable running at ODI with the slight altitude change?
SherwinX said:George Smooth said:Was the difference in boost pressure measurable running at ODI with the slight altitude change?
No, no difference at all. Runing 0.4 bar at 8000rpm, 0.45 at 8400rpm at 1600m elevation.
At ODI, the elevation was 1200m. It's hard to see the difference on a boost gauge. Looked about the same.
Times & exits were identical from Tarlton last time I went. 11.6 at 200 at Tarlton. 11.6 at 200 at ODI. But the belt has been slipping all the while. Today was the 1st time the belts didn't slip as I finally did something about it. And the exits went up to 203-204. Helps with time at the end as well. But major drop in time was from not using launch control. Altitude had nothing to do with it as my 1st 3 runs today were all 11.7. It's only from driving changing that the time dropped.
Awesome stuff Sherwin :thumbs:dvst8 said:Sherwin ran 270km/h today at ODI on the 1km. Speed limiters still in place and the M3 was on that limiter before the 1km mark.
Also ran a 11.2 on the 400m.
Well done Sherwin and Xcede !
raise:
George Smooth said:Cool stuff. In theory with a fixed belt charger the gains are very small over such a change. Just needed to know for future reference.
George Smooth said:By the way my buddies where on a breakfast run this morning and they told me you ripped all their exotics a new one.
SherwinX said:George Smooth said:By the way my buddies where on a breakfast run this morning and they told me you ripped all their exotics a new one.
Yeah ran some Lambo's, M6, Maserati, Aston's. They got a bit of a shock as they were lining up to pick on the M3. :rollsmile:
