X35 heatsoak
Hubblyking
[/font]Hi guys I am experiencing heatsoak problems,after my frc phase2 ,dp and intake upgrade should I go back to phase1.Did anyone go through this problem .Will a upgraded cooler help?my first two launches has lot of punch but power drops afterwards:thumbdo:
A
anile8-zn
u need a cooler or water meth !
what intake do u have?
stock box is best in my testing
Hubblyking
I also had dci but heat killed me
A
anile8-zn
wow that looks cool!!!
did it make any difference?
did u cut up your airbox?
Twinz
Forum - Support
Go for IC and water/meth since you drag race.
I would do away with the Mr 5 mod. That mod was an idea that OB from chiplogic and I discussed already during 2007 for the X35 platform (actually OBs idea) then we saw Mr 5 posting pix on e90 which was simmilar to our discussion...however, we realised after testing that the stock box (with K&N filter) or the DCI's will work best or a custom made CAI and I think OB leaned more towards the latter...I prefer the DCI's.
However, I am not saying the Mr5's mod is not working...just that it is unnecessary compared to available options.
Hubblyking
Yes the only prob is to replace it is a he'll lot of money for that extra bit of power. My car is going back to frc just to check if it's not the map.after all the mods was done I didn't have the problem,but after the new map it started messing around.I I made like 308hp and 452 torque in third on the frc dyno before they changed the map .I see the other guys are making more power but going to the track next week.So I have to sort my cooling probs
A
anile8-zn
i have the new map , it is ment to be used with cooling mods and dv's
Hubblyking
I've got the forge dvs can u pm me where to get the cooler,where are based cause I see u also have frc were did u dyno
George Smooth
A big factor also to take into account is the cost of replacing the airbox which at the time was in the region of R8500.
Hubbly, the heat soak you are experiencing is not related to the intake temperatures. Are your oil temperatures going high and you getting boost decay?
Dropping intake temps does help to a certain extent either using methanol which is the most affective or by adding a intercooler. The advantage varies between a few cars relative to how efficient your cooling system is. I have started to believe that carbon build up on the valves also affect cooling efficiency so this will be affected with how much mileage is on your car.
Running the car slightly richer also makes a difference.
M3_devil
Also, that extra intake pipe must have a filter ( seeing that it enters the box where the filtered air goes to turbo) on otherwise the turbo's are gonna get damaged from debri that gets sucked in.
Hubblyking
I've got a filter in that pipe.my oil temp is going to 125 what do u guys reckon should I go back to phase 1 or replace the cooler .I've got50000k on the clock.I think George knows what I'm talking about because with this problem the oil temp is over 120degrees
