Wynn's Products - smaller quantities / samples courtesy of G Shift
gavsadler
Hi all,
Something I have been working on in the background (as part of bigger plans), is to offer some of my favourite products, in smaller quantities.  The reason for this is that some of these products may be more expensive than other products on the market, and for many consumers, price sensitivity is real.  This, coupled with "not knowing", means that often it is hard to justify spending more on a particular product, and after a couple of uses, you decide it's not for you.
What happens then is that your shelves / cupboards get full of half used, or barely used products, because you have moved on to something else.  Not ideal.  Experiences like this also set the precedent going forward, where you are perhaps now even more reluctant to try something else or something new.  It is almost considered a sunk cost, a waste of money.
ac
So, I've been busy behind the scenes, putting together some of my favourite products in smaller quantities.  These are generally enough for a handful of uses.  The intention being:
  1. Try it out, if you like it, then you can purchase the standard size products going forward
  2. If you don't like it, you're not left with plenty of half-used products.
  3. The cost of the smaller quantities is a lot less, so it makes it more palatable to try something new.
  4. They can make great gifts (more on this coming soon).
For Wynn's, there are a few products which I use on my regular basis, so I'm pleased to offer the following:
  • Cleen Green in 500ml bottles:  At present, you can only get the regular Cleen Green in a squeezer bottle, but this has been discontinued and is being phased out.  Given that I'm a reseller, I'm able to purchase it in bigger quantities and have decided to offer it in 500ml bottles.  Also, I'm offering it in the 3 current variants, those being Original, Lemon and Lavender.
  • C Thru in 100ml: this stuff is great to apply to outside glass, mirrors, headlights and so on. In the 100ml size, it should be good for 2-3 applications on a vehicle.
  • Leather Care Creme in 100ml: I also use this regularly, it is also good for 2-3 applications for leather in a vehicle.
I'll probably be adding more products as we go along, so stay tuned for further updates.
All products are now live and available in the online store, so check it out: www.gshift.co.za
Current pricing is as follows:
