Bruce,
If you need a hand, just shout.
Big ups for taking this one on.
Its not a very complicated motor at all, but some minor ramblings from my side, on a few items, stuff I wish I knew on my first couple of jobs like this.
Cams and heads can warp/break if you remove them incorrectly.
Always go from the outter edges inwards, criss cross on those two items.
Else if you release the tension on the right hand side completely, and not the left, you will warp/bend head and cam.
Are you going to pull the motor to do the sump/cleaning properly.
It is a flippen biatch to get to the sump/other stuff while its still in the car.
If you are going to pull the motor, may I suggest that you just disconnect water pipes, remove the exhaust, remove the gearbox, and leave the motor intact.
Your lifting points for the motor are actually on the head, so if you remove the head, its just so much more difficualt to remove the engine.
Why don't you run your plan past us, as to what exactly you want to do, so that we can give you some more guidance..
Oh and you don't need really fancy tools to pull the motor,
Adendorff does an engine stand for under R500, and its an investment.
You also do not need an engine crane to pull it out.
If you have roof trusses in your garage, you can just buy a block and tackle from adendorff as well.
I picked up a 2 ton one on the bargain stand at addendorff which was scratched for like R200.
Also another industry secret, most of these engine parts can be bought from Alert Engine spares, they are a major importer of engine parts such as gasket sets, valves, bearings ect, most aftermarket spares shops will buy from Alert, put a markup on it, and call it a day.
We are all here to help, give a shout.
Oh, and budget for a water pump and a thermostat while your in there...
