Driving from work today my drivers side window acted funny, it rolls down ok but not back up but if i lock the car and keep the lock button in it rolls up 100%. So what can this be.
Car:
2003 325ci
Thats weird. No clue what it could be. Perhaps not enough power when its winded up.
The key uses alot more power when you lock the car and rolling up the windows and sunroof...it needs power to do all those things simultaneously :thumbs:
Car:
2003 325ci
Car:
2003 325ci
Real long long shot here...but could it not be the finger/hand safety strip (not sure of what its called but it keeps your fingers from being closed on accidentally) in the upper window rubber is damaged and its not allowing the window to close under the instruction of the button but when using the key that's being over ridden?
What happend to my Brother in laws car was the same so we took out the Switches and opend it up.
there is two very thin Wires running inside that makes contact with the plate as soon as you flick it up or down. in his case the two did not touch the metal part and we had to bend it back to sort it.
it sounds def like the Switch.
It is very basic and simple do it your self job. :thumbs: Im guessing you have the same Problem
