Wind noise on coupe
Lazer
Is there any way to reduce the wind noise on a coupe's doors? From about 140 onwards I get progressively worse wind noise...
I spoke to someone who works for BMW, who told me that the cars are specced to work up until 100km/h, so anything more than that is "unnatural" and they won't be able to do anything about it!
WyKiD
That does not sound right, which coupe do you have? Might be an issue with the door rubbers not sealing correctly, could also be an issue with the longer/heavier coupe doors not being aligned correctly and sagging a bit.
I had an e36 convertible no issues with wind noise even with the soft top, up to twice legal limits.
JPV135i
No non of that will actually work iv tried a couple of things including some of the above and unfortunately non worked well atleast not on my coupe... The problem seems to be that the top of the window doesn't actually seal proplerly!
Lazer
This sounds about right... I've also got a 135i Coupe.
